USB Type-C Adapter Cable 4K 60Hz Thunderbolt 3 . This USB-C to DisplayPort 1.2 cable lets you connect your USB Type-C (or Thunderbolt 3 ) device to a DisplayPort display, or a DP device to a USB-C display with just one cable.
Easy & Clutter-Free Installation
At 3.3 ft. (1 m) in length, this bidirectional adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, we also offer a 6.6 ft. (2 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs.
As well, the cable works with both Mac and Windows devices and allows for plug-and-play installation, removing the need for any additional software or drivers.
Convenient, Bi-Directional Support
Use this USB-C to DisplayPort adapter cable to output 4K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input.
Ultra HD 4K Resolution at 60Hz
This USB-C to DP 1.2 adapter cable lets you harness the video capabilities that are built into your computer's USB Type-C (or DisplayPort) connection, to deliver the astonishing quality of UHD to your 4K display. For even higher resolution and bandwidth support, we offer a USB-C to DP 1.4 cable, which is the perfect accessory for early adopters of 8K.
CDP2DP1MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable.
Easy & clutter-free installation
This?bi-directional adapter cable delivers a compact?connection that eliminates excess adapters and cabling,?ensuring?a tidy, professional installation. -
Convenient support
Use this USB-C to DisplayPort adapter cable to output video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input.
- StarTech 3ft (1m) USB C to DisplayPort 1.2 Cable 4K 60Hz, Bidirectional DP to USB-C or USB-C to DP Reversible Video Adapter Cable, HBR2/HDR, USB Type C/Thunderbolt 3 Monitor Cable - 4K USB-C to DP Cable - DisplayPort cable - USB-C to DisplayPort - 1 m
- DisplayPort cable
- 4K support, active cable, DisplayPort Alternate Mode support, bidirectional
- Cable Length
- 1 m
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- 20 pin DisplayPort - female (output)
- USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
- Black
- 3-year warranty
- DisplayPort cable
- Cable Length
- 1 m
- Black
- Connector
- 3-year warranty
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £20.49 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £11.44 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.97 |
StarTech.com 10ft USB-C to DP Adapter Cable | In Stock | £19.49 |
StarTech.com 6.6ft USB C to DP 1.2 Cable | In Stock | £31.29 |
