Active Video Converter USB-Powered Mac & Windows . This 3.3 ft. HDMI to Mini DisplayPort cable (male to male) lets you connect an HDMI video source, such as your laptop, desktop, Blu-ray player or camera, to a Mini DP monitor or display without the need for additional video cables and adapters.
Astonishing Picture Quality
With support for 4K at 30Hz, you get a sharp, crisp picture that's richer and more true-to-life than traditional HD, with far greater detail. The HDMI to Mini DisplayPort adapter cable delivers UHD content to your mDP display and supports 7.1 channel surround audio.
The video converter is also backward compatible with 1440p and 1080p displays, which makes it a great accessory to for your existing setup at home or in the office.
Clutter-Free Installation
At 3.3 ft. (1 m) in length, this HDMI to mDP cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, we also offer a 6.6 ft. (2 m) adapter cable, enabling you to choose the right cable length for your custom installation needs.
Convenient Connectivity
This active HDMI to Mini DP converter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install. The adapter cable is powered via a USB port, avoiding the need for external power adapters.
HD2MDPMM1M is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Astonishing picture quality
With support for 4K at 30Hz, you get a sharp, crisp picture that's richer and more true-to-life than traditional HD, with far greater detail. The HDMI to Mini DisplayPort adapter cable delivers UHD content to your mDP display and supports 7.1 channel surround audio. The video converter is also backward compatible with 1440p and 1080p displays, which makes it a great accessory to for your existing setup at home or in the office. -
Clutter-free installation
This HDMI to mDP cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. -
Convenient connectivity
- StarTech.com 3ft (1m) HDMI to Mini DisplayPort Cable 4K 30Hz, Active HDMI to mDP Adapter Converter Cable with Audio, USB Powered, Mac & Windows, HDMI Male to mDP Male Video Adapter Cable - HDMI to mDP Converter (HD2MDPMM1M) - video / audio cable - DisplayPort / HDMI - 1 m
- Cable
- Video / audio cable - DisplayPort / HDMI
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Length
- 1 m
- Black
- Connectors
- HDMI - male , USB (power only) - male
- Connectors (Second End)
- Mini DisplayPort - male
- 4K support
- 3-year warranty
- Cable Type
- Video / audio cable 4K support
- Interface Supported
- Jacket Material
- Plastic
- Length
- 1 m
- USB powered, active converter
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- Connectors
- 19 pin HDMI Type A - male , 4 pin USB Type A (power only) - male
- Plug and Play, FCC, RoHS, REACH
- 67.5 g
- Shipping Width
- 21.8 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 75.4 g
- Limited warranty - 3 years
