This USB-C to DisplayPort adapter cable lets you connect your USB Type-C device to a DisplayPort monitor with just one cable, providing you with a convenient, clutter-free solution.
Supporting four times the resolution of 4K, this8K DP 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography.
The DP adapter is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
At 3.3 ft. (1 m) in length, this adapter delivers a compact connection that eliminates excess cabling, ensuring a tidy installation. For installations requiring a longer length, a 5.9 ft (1.8 m) (CDP2DP146B) DisplayPort cable enables you to customize your connection needs.
To ensure easy operation, this DP adapter supports plug-and-play installation, removing the need for additional software or drivers.
Note: Your USB-C device must support DP Alt Mode to work with this adapter.
High resolution support
Experience visuals with a maximum external resolution of 7680 x 4320, providing a clear picture for high-definition needs. -
Broad device compatibility
This cable supports Thunderbolt 3 devices and operates in DisplayPort Alternate Mode, ensuring connectivity across various platforms. -
Smooth video playback
Features support for HBR3, enabling high bandwidth for smooth video streaming and a V-Sync rate of 30 Hz at maximum resolution. -
Sturdy design
Constructed with durable materials, this cable is designed for long-lasting performance while maintaining a sleek and portable form factor.
- StarTech.com 3.3ft/1m USB C to DisplayPort 1.4 Cable, 4K/5K/8K USB Type-C to DP 1.4 Alt Mode Video Adapter Converter, HBR3/HDR/DSC, 8K 60Hz DP 1.4 Monitor Cable for USB-C and Thunderbolt 3 - USB-C to DP 8K Cable (CDP2DP141MB) - external video adapter - black
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- - up to
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DisplayPort (male connector)
- Length
- 1 m
- Enclosure Colour
- Black
- 3-year warranty
- Designed For
- P/N: TB4CDOCK
- Bus Type
- USB-C
- Max Resolution
- 7680 x 4320 at 30 Hz
- 8K Display Support, Thunderbolt 3 compatible, DisplayPort Alternate Mode, HBR3 support
- DisplayPort 1.4
- Length
- 1 m
- Enclosure Colour
- Black
- Limited warranty - 3 years
- Designed For
- P/N: TB4CDOCK
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £14.07 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £11.69 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £14.86 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £30.40 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £23.07 |
StarTech.com USB-C to DisplayPort MST Hub - 2-Port | In Stock | £40.20 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.55 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £20.76 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £18.05 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £24.08 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £19.97 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £22.34 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.79 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £17.06 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £31.40 |
