StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K
Quicklinx: FC09WS00 Mfr#: CDP2DP141MB
Length: 1m
£23.05 ex VAT
£27.66 inc VAT
This USB-C to DisplayPort adapter cable lets you connect your USB Type-C device to a DisplayPort monitor with just one cable, providing you with a convenient, clutter-free solution.
Supporting four times the resolution of 4K, this8K DP 1.4 adapter delivers the stunning quality of UHD at resolutions up to 7680×4320, and also features HBR3 functionality, providing a bandwidth of up to 32.4Gbps.
With cutting-edge picture quality, this adapter is ideal for: Displaying crisp digital signage walls; Creating eye-catching visuals for photography and videography.
The DP adapter is backward compatible with 4K and 1080p displays, which makes it a great accessory for home, office or other work environments, while future-proofing for 8K implementation.
At 3.3 ft. (1 m) in length, this adapter delivers a compact connection that eliminates excess cabling, ensuring a tidy installation. For installations requiring a longer length, a 5.9 ft (1.8 m) (CDP2DP146B) DisplayPort cable enables you to customize your connection needs.
To ensure easy operation, this DP adapter supports plug-and-play installation, removing the need for additional software or drivers.
Note: Your USB-C device must support DP Alt Mode to work with this adapter.
  • High resolution support
    Experience visuals with a maximum external resolution of 7680 x 4320, providing a clear picture for high-definition needs.
  • Broad device compatibility
    This cable supports Thunderbolt 3 devices and operates in DisplayPort Alternate Mode, ensuring connectivity across various platforms.
  • Smooth video playback
    Features support for HBR3, enabling high bandwidth for smooth video streaming and a V-Sync rate of 30 Hz at maximum resolution.
  • Sturdy design
    Constructed with durable materials, this cable is designed for long-lasting performance while maintaining a sleek and portable form factor.
StarTech.com 3.3ft/1m USB C to DisplayPort 1.4 Cable, 4K/5K/8K USB Type-C to DP 1.4 Alt Mode Video Adapter Converter, HBR3/HDR/DSC, 8K 60Hz DP 1.4 Monitor Cable for USB-C and Thunderbolt 3 - USB-C to DP 8K Cable (CDP2DP141MB) - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
7680 x 4320
Interfaces Details
DisplayPort (male connector)
Length
1 m
Enclosure Colour
3-year warranty
P/N: TB4CDOCK
Bus Type
USB-C
Max Resolution
7680 x 4320 at 30 Hz
Interfaces Details
8K Display Support, Thunderbolt 3 compatible, DisplayPort Alternate Mode, HBR3 support
DisplayPort 1.4
Length
1 m
Enclosure Colour
Limited warranty - 3 years
P/N: TB4CDOCK
FC09 StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.38
FC09 StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.54
FC09 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
FC09 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.73
FC09 StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
FC09 StarTech.com USB-C to DisplayPort Adapter In Stock £20.19
FC09 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
FC09 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
FC09 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
FC09 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
FC09 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
FC09 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.97
FC09 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.47
FC09 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
Length: 1m
