StarTech.com 3 + 1P Internal PCI Express FireWire Card
Quicklinx: 4YLNWS00 Mfr#: PEX13943
  • Windows 8 (32/64 bits)
This 4 Port PCI Express 1394a FireWire Adapter Card turns a PCI Express slot into three external and one internal 1394a ports, allowing you to connect portable drives, digital camcorders and more to your desktop computer.
The adapter card supports hot-swapping, so you'll be able to plug, unplug, and swap your FireWire peripherals with ease, without having to power down the computer. It also includes a low profile bracket that makes the adapter card suitable for installation in slimline or small/micro form factor systems.
StarTech.com 4 Port PCI Express 1394a FireWire Adapter Card - 3 External 1 Internal - FireWire adapter - PCIe - 3 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports Qty
3 ports
Firewire
Data Transfer Rate
400 Mbps
Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
FireWire adapter - 3 ports
Plug-in card
PCI Express x1
Wired
IEEE 1394 (FireWire)
Data Transfer Rate
400 Mbps
3 x FireWire - 6 PIN FireWire (external) , 1 x FireWire - 6 PIN FireWire (internal)
Compatible Slots
1 x PCI Express x1
WHQL, FCC, RoHS
Limited warranty - lifetime
