StarTech.com 2x2 VGA Matrix Video Switch Splitter with Audio
Quicklinx: 7P2RWS00 Mfr#: ST222MXA
The ST222MXA 2x2 VGA Matrix Switcher/Splitter allows you to share 2 distinct VGA inputs (as well as a corresponding audio source), between 2 independent displays or projectors.
Providing convenient push-button control, the VGA Matrix Switcher/Splitter allows each of the 2 input VGA signals and the corresponding audio, to be switched individually - meaning that you can have a different source showing on each display, or one source showing on both, offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management over longer distance signal transmissions, the ST222MXA VGA Matrix Switch features a built-in signal booster that facilitates installation of displays at distances of up to 213-feet (65 meters) away from the source device, while maintaining flawless signal integrity.
StarTech.com 2x2 VGA Matrix Video Switch Splitter with Audio - Video/audio switch - desktop - ST222MXA - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
VGA / audio
13 cm x 7.5 cm x 4.2 cm
450 g
1-year warranty
P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
VGA / audio
Max Resolution
1920 x 1440 @ 85 Hz
Max Video Bandwidth
250 MHz
Status Indicators
Port status
2 x VGA input HD-15 , 2 x VGA output HD-15 , 2 x audio input mini-jack , 2 x audio output mini-jack
External power adapter
FCC, RoHS
13 cm
7.5 cm
4.2 cm
450 g
Limited warranty - 1 year
70 °C
0 - 95%
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
7P2R StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
7P2R StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.83
7P2R StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
7P2R StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.68
7P2R StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
7P2R StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
