The ST222MXA 2x2 VGA Matrix Switcher/Splitter allows you to share 2 distinct VGA inputs (as well as a corresponding audio source), between 2 independent displays or projectors.
Providing convenient push-button control, the VGA Matrix Switcher/Splitter allows each of the 2 input VGA signals and the corresponding audio, to be switched individually - meaning that you can have a different source showing on each display, or one source showing on both, offering maximum flexibility and control.
To ensure optimized VGA distribution and signal management over longer distance signal transmissions, the ST222MXA VGA Matrix Switch features a built-in signal booster that facilitates installation of displays at distances of up to 213-feet (65 meters) away from the source device, while maintaining flawless signal integrity.
- StarTech.com 2x2 VGA Matrix Video Switch Splitter with Audio - Video/audio switch - desktop - ST222MXA - video/audio switch - 2 ports
- Video/audio switch - 2 ports
- Subtype
- VGA / audio
- 13 cm x 7.5 cm x 4.2 cm
- 450 g
- 1-year warranty
- Designed For
- P/N: IM12D1500P, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- VGA / audio
- Max Resolution
- 1920 x 1440 @ 85 Hz
- Max Video Bandwidth
- 250 MHz
- Status Indicators
- Port status
- 2 x VGA input HD-15 , 2 x VGA output HD-15 , 2 x audio input mini-jack , 2 x audio output mini-jack
- Power Device
- External power adapter
- FCC, RoHS
- 13 cm
- 7.5 cm
- 4.2 cm
- 450 g
- Limited warranty - 1 year
- 0 °C
- 70 °C
- 0 - 95%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
