Discover hassle-free HDMI connection, automatic video port selection, and guaranteed picture quality perfection. Save time and hassle by automatically switching between your HDMI audio/video sources, using the VS222HDQ 2X2 HDMI Matrix Switcher. This easy-to-use HDMI Matrix switch ensures seamless transition while switching video and display sources, with EDID copy maintaining your video resolution.
Ensure seamless transition while switching video sources, with EDID copy maintaining native resolution with support for 1080p. Video connection emulation ensures the settings on any connected computers are not disrupted while switching to a different video source.
Save time by connecting two HDMI video source devices to two independent HDMI displays instead of manually connecting individual cables. Mounting hardware is also included for a tidy, professional installation.
Enjoy hassle-free operation with four different switching modes:
Automatic port selection: Enables your most recently activated video source to be displayed automatically.
Priority port selection: Prioritizes input number two above input number one. If the video source connected to input number two is activated that source will be displayed.
Matrix port selection: Independently switch two displays between two video sources.
Manual port selection: Enables you to manually select your HDMI source with easy-to-use front panel buttons.
- StarTech.com 2x2 HDMI Matrix Switch with Remote - 1080p Automatic & Priority Switcher - Video Wall Auto Selector Splitter Box - Audio Out (VS222HDQ) - video/audio switch - 2 ports
- Video/audio switch - 2 ports
- Subtype
- HDMI
- HDCP compliant
- Power
- AC 120/230 V
- 15.6 cm x 6.5 cm x 2 cm
- 278 g
- Black
- Localisation
- United Kingdom, United States, Europe
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Max Resolution
- 3840 x 2160
- HDCP compliant
- Status Indicators
- Port status
- 2 x HDMI input , 2 x HDMI output
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Included Accessories
- Remote control
- Rack Mounting Kit
- Included
- FCC, RoHS
- Localisation
- 15.6 cm
- 6.5 cm
- 2 cm
- 278 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.52 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £10.03 |
StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p | In Stock | £63.43 |
StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p | In Stock | £94.34 |
StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall | In Stock | £1,106.58 |
StarTech.com 4-Port 4K HDMI Video Switch | In Stock | £138.09 |
StarTech.com 2-Port 4K HDMI Video Switch | In Stock | £94.18 |
StarTech.com 2x2 HDMI Matrix Switch - 4K | In Stock | £138.09 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.61 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
