StarTech.com 2x2 HDMI Matrix Switch - 4K
Quicklinx: BRVJWS00 Mfr#: VS222HD4K
Type: Video/audio switch
Ports: 2
Connectivity: HDMI
£143.94 ex VAT
£172.72 inc VAT
Automatically switch between two 4K video sources on two displays, utilizing fast-switching technology. Save time and hassle by automatically switching between your HDMI audio/video sources. This 2x2 HDMI matrix switcher provides the ultimate viewing experience, with support for Ultra HD 4K. It lets you connect two HDMI sources to two HDMI displays, with exceptional 4K resolution, while switching seamlessly between your video sources.
The matrix switch supports Ultra HD 4K picture quality on two monitors while switching between content from HDMI source devices - including Blu-ray players or DVD players, computer systems, video game consoles, digital cable or satellite boxes, and A/V receivers.
4K support ensures a higher level of image clarity and visibility, delivering four times the resolution of 1080p - 8.29 million pixels versus 2.07 million pixels. It provides a more engaging visual experience for audiences in a wide range of venues including conference centers, boardrooms, educational facilities, and commercial settings. With its exceptional image quality, 4K resolution is also ideal for bringing your digital signage to life.
Enjoy hassle-free operation with four different switching modes:
Matrix switching: lets you route either HDMI source (Input 1 or Input 2) to either monitor (Output 2 or Output 3) - and independently switch two displays between two video sources.
Fast auto switching: ensures minimal time for switching between HDMI sources. The switch provides effortless operation with advanced auto-sensing - it detects the latest connected HDMI source and automatically switches both outputs to that device.
Priority switching: identifies the first port to have first priority for HDMI sources, which will be output on both displays.
Manual switching: enables you to manually select your HDMI source with front-panel buttons that are easy to use.
An IR remote control is included in the box, enabling you to easily select your desired input source remotely.
The matrix switch is easy to install. EDID emulation saves you time during setup by ensuring all of your display settings, such as native resolution and refresh rate, are communicated between your display and video source devices. The built-in EDID copy feature maximizes compatibility with your 4K display, to ensure a convenient plug-and-play installation and the sharpest image quality.
  • Versatile connectivity
    This matrix switcher features two HDMI inputs and outputs, allowing users to easily switch between different video and audio sources without hassle.
  • High-resolution output
    With support for 4K resolution, the switcher ensures sharp and clear video output, making it suitable for high-definition displays.
  • Audio support
    The 7.1 channel audio support delivers an immersive sound experience, complementing the video for a complete multimedia experience.
  • Easy monitoring
    The matrix switcher is equipped with port and power status indicators, providing users with real-time feedback on the device's operational status.
  • Environmentally compliant
    This product meets FCC, RoHS, WEEE, and RCM compliance standards, ensuring it adheres to environmental sustainability and safety regulations.
StarTech.com 2x2 HDMI Matrix Switcher - 4K UltraHD HDMI Switch with Fast Switching, Auto-Sensing and Serial Control (VS222HD4K) - video/audio switch - 2 ports
Video/audio switch - 2 ports
Subtype
HDMI
Ports
2 x HDMI
4K resolution support, 7.1 channel audio support
AC 120/230 V
Australia, North America, United Kingdom, Europe
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Status Indicators
Port status, power
2 x HDMI input , 2 x HDMI output
External power adapter
AC 120/230 V
Remote control
1 x RJ-11 phone cable , 1 x DB-9 to RJ-11 adapter
FCC, RoHS, WEEE, RCM
50 °C
BRVJ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
BRVJ StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p In Stock £87.36
BRVJ StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall In Stock £637.10
BRVJ StarTech.com 4-Port 4K HDMI Video Switch In Stock £120.78
BRVJ StarTech.com 2-Port 4K HDMI Video Switch In Stock £90.59
BRVJ StarTech.com 2x2 HDMI Matrix Switch - 4K In Stock £143.94
BRVJ StarTech.com 4x4 HDMI Matrix Switch w/Audio In Stock £503.09
Ports: 2
Connectivity: HDMI
