Charge two tablets simultaneously, in your car. This 2-port car charger lets you charge two mobile devices simultaneously, while you're driving.
The charger can deliver 24 watts of power in total, sharing 4.8 amps of power between both ports. This means that you can charge two tablets at the same time.
The dual-port charger features Smart IC technology, which enables it to identify what type of device is connected to each port. By recognizing the attached device, the charger delivers the optimal charge that's specific to each device.
The charger supports USB Battery Charging Specification 1.2, which ensures compatibility with a broad range of mobile devices, including the Apple iPhone and iPad, the Microsoft Surface tablet, the Samsung Galaxy Tab, Nexus phones and more. When you're traveling with a passenger, you can charge their device as well as yours, and ensure that both of your mobile devices are ready when you arrive.
- StarTech.com Dual Port USB Car Charger - High Power 24W/4.8A - Black - 2-Port USB Car Charger - Charge two tablets at once (USB2PCARBKS) car power adapter - USB - 24 Watt
- Product Type
- Car power adapter
- 30 g
- Black
- Output Connector Type
- Total 2: USB
- Voltage Required
- 12 - 24 V
- Voltage Provided
- 5 V
- Max Electric Current
- 4.8 A
- Power Provided
- 24 Watt
- 2-year warranty
- Designed For
- P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
- Product Type
- Car power adapter
- Designed For
- Tablet, mobile phone
- 30 g
- Enclosure Colour
- Black
- Voltage Required
- 12 - 24 V
- Input Connectors
- Automobile cigarette lighter
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Power Provided
- 24 Watt
- 4.8 A
- FCC, RoHS, WEEE
- Limited warranty - 2 years
- Designed For
StarTech.com Micro USB to Mini USB Adapter | In Stock | £5.62 |
StarTech.com Mini USB to Micro USB Adapter | In Stock | £5.72 |
StarTech.com 6in Micro USB Cable - A to Micro B | In Stock | £3.89 |
StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F | In Stock | £6.43 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.24 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.53 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £19.89 |
StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port | In Stock | £25.36 |
StarTech.com Car Charger - Micro USB & USB | In Stock | £10.19 |
StarTech.com 3ft Right Angle Micro-USB Cable | In Stock | £4.79 |
StarTech.com 6ft Right Angle Micro-USB Cable | In Stock | £5.93 |
StarTech.com 3ft Micro-USB Charging Cable | In Stock | £4.93 |
StarTech.com 3 ft Micro-USB Charging Cable | In Stock | £4.79 |
StarTech.com 6 ft Micro-USB Charging Cable | In Stock | £7.69 |
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £13.33 |
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £11.36 |
StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.60 |
StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.50 |
