StarTech.com 2x USB Car Charger 24W / 4.8A
Quicklinx: C9WVWS00 Mfr#: USB2PCARBKS
Type: Charger
28 In Stock
£12.51 ex VAT
£15.01 inc VAT
Charge two tablets simultaneously, in your car. This 2-port car charger lets you charge two mobile devices simultaneously, while you're driving.
The charger can deliver 24 watts of power in total, sharing 4.8 amps of power between both ports. This means that you can charge two tablets at the same time.
The dual-port charger features Smart IC technology, which enables it to identify what type of device is connected to each port. By recognizing the attached device, the charger delivers the optimal charge that's specific to each device.
The charger supports USB Battery Charging Specification 1.2, which ensures compatibility with a broad range of mobile devices, including the Apple iPhone and iPad, the Microsoft Surface tablet, the Samsung Galaxy Tab, Nexus phones and more. When you're traveling with a passenger, you can charge their device as well as yours, and ensure that both of your mobile devices are ready when you arrive.
  • Efficient power output
    This car power adapter delivers a total power of 24 watts, providing fast charging capabilities for your devices.
  • Dual charging capability
    Equipped with two USB Type-A output connectors, it allows for charging two tablets or phones at the same time.
  • Safety compliant
    Meets FCC, RoHS, and WEEE standards, ensuring that the charger aligns with safety and environmental guidelines.
  • Universal compatibility
    Designed for use with tablets and cellular phones, making it a versatile accessory for various devices.
  • Convenient design
    The compact size fits easily into the automobile cigarette lighter, providing a practical solution for on-the-go charging.
Startech Dual Port USB Car Charger - High Power 24W/4.8A - Black - 2-Port USB Car Charger - Charge two tablets at once (USB2PCARBKS) car power adapter - USB - 24 watt
Car power adapter
Tablet, mobile phone
30 g
Output Connector Type
Total 2: USB
12 - 24 V
Voltage Provided
5 V
Max Electric Current
4.8 A
Power Provided
24 watt
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Car power adapter
30 g
Enclosure Colour
12 - 24 V
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
24 watt
4.8 A
FCC, RoHS, WEEE
C9WV StarTech.com Mini USB to Micro USB Adapter In Stock £3.67
C9WV StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
C9WV StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F In Stock £6.13
C9WV StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
C9WV StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £15.14
C9WV StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £17.97
C9WV StarTech.com 3ft Right Angle Micro-USB Cable In Stock £5.22
C9WV StarTech.com 6ft Right Angle Micro-USB Cable In Stock £6.18
C9WV StarTech.com 6 ft Micro-USB Charging Cable In Stock £7.11
C9WV StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £12.51
C9WV StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
Type: Charger
