StarTech.com 2x SFF-8643 to 8644 Adapter
Quicklinx: CFQPWS00 Mfr#: SFF86448PLT2
£56.99 ex VAT
£68.38 inc VAT
Convert two internal SFF-8643 ports into two external SFF-8644 ports. This Mini-SAS adapter lets you convert two internal SFF-8643 ports on a controller card into two external SFF-8644 ports. This enables you to connect external SAS or SATA drives in devices such as a Direct Attached Storage (DAS) device to an internal backplane or SAS controller for additional storage.
The adapter can connect up to eight drives in total and is compatible with 12Gbps SAS drives as well as 6Gbps SATA drives. For installation in small form-factor computers, the adapter includes an optional half-height (low-profile) bracket, in addition to the preinstalled standard-height bracket.
StarTech.com Mini-SAS Adapter - Dual SFF-8643 to SFF-8644 - with Full and Low-Profile Brackets - 12Gbps - SAS internal to external panel
Interface Speed
SAS 12Gbit/s
Low profile
Connector
2 x 36 pin 4x Mini SAS HD (SFF-8643) - female
Connector (Second End)
2 x 36 pin 4x Mini SAS HD (SFF-8644) - female
Storage Cable Type
Interface Speed
SAS 12Gbit/s
Low profile
124 g
Connector
FCC, RoHS
CFQP StarTech.com U.2 2.5" NVMe SSD Adapter In Stock £22.26
CFQP StarTech.com 1m SFF-8643 to 4x SATA Cable In Stock £24.82
CFQP StarTech.com 1m SFF-8087 to SFF-8643 Cable In Stock £29.80
CFQP StarTech.com U.2 to M.2 Adapter In Stock £13.17
Price Range Ex VAT: 50 - 100
