Convert two internal SFF-8643 ports into two external SFF-8644 ports. This Mini-SAS adapter lets you convert two internal SFF-8643 ports on a controller card into two external SFF-8644 ports. This enables you to connect external SAS or SATA drives in devices such as a Direct Attached Storage (DAS) device to an internal backplane or SAS controller for additional storage.
The adapter can connect up to eight drives in total and is compatible with 12Gbps SAS drives as well as 6Gbps SATA drives. For installation in small form-factor computers, the adapter includes an optional half-height (low-profile) bracket, in addition to the preinstalled standard-height bracket.
- StarTech.com Mini-SAS Adapter - Dual SFF-8643 to SFF-8644 - with Full and Low-Profile Brackets - 12Gbps - SAS internal to external panel
- Interface Speed
- SAS 12Gbit/s
- Low profile
- Connector
- 2 x 36 pin 4x Mini SAS HD (SFF-8643) - female
- Connector (Second End)
- 2 x 36 pin 4x Mini SAS HD (SFF-8644) - female
- 2-year warranty
- Storage Cable Type
- Interface Speed
- SAS 12Gbit/s
- Low profile
- 124 g
- Connector
- RoHS, FCC
- 2-year warranty
StarTech.com U.2 2.5" NVMe SSD Adapter | In Stock | £21.67 |
StarTech.com 1m SFF-8643 to 4x SATA Cable | In Stock | £26.02 |
StarTech.com 1m SFF-8087 to SFF-8643 Cable | In Stock | £37.36 |
