Brand
StarTech.com 2x M.2 SSD Controller - PCIe
Quicklinx: BST6WS00 Mfr#: PEX2M2
Compatibility: PC
Hurry, only 2 left in stock!
£54.95 ex VAT
£65.94 inc VAT
Add two Next Generation Form Factor (NGFF) M.2 SATA SSDs to your computer through PCI Express. This M.2 SSD controller card lets you install two M.2 SATA solid-state drives (SSD) into your PC through PCI Express. You can mount virtually any M.2 drive directly to the card, giving you a convenient and discreet way to improve your computer system performance. Plus, the card is a vital computer add-on if you need to recover data from an existing M.2 drive, or for expanding your overall internal storage.
This M.2 controller card lets you take full advantage of the performance and size benefits of NGFF (Next Generation Form Factor) SSDs. M.2 drives are smaller than typical platter drives or mSATA-based SSDs, so you can install them in tighter areas within your computer case. By freeing up space within your computer, you'll also have more room for additional hardware upgrades.
When you couple the card with an M.2 drive, you can give your computer's performance a noticeable speed boost, enabling you to replace your platter drive with a faster M.2 SATA III (6Gbps) solid-state drive. By installing your operating system on the M.2 drive, you'll have faster access to the files you commonly use, and you can continue to use your higher-capacity platter HDD for bulk storage.
Due to their performance and size advantages, M.2 drives are commonly used in laptops. If your laptop has failed but its M.2 drive is functional, then this card can help with data recovery. Once the M.2 drive is installed and the data recovery is complete, you can continue to use the drive for storage and backup purposes.
You can also rest assured that your M.2 SATA drives are compatible with the card. It supports the most common drive sizes, including 22110, 2280, 2260, 2242 and 2230.
The M.2 controller provides additional installation flexibility with a dual-profile design that fits standard or low-profile cases, so it's the perfect solution for small form-factor or full-sized computers.
This M.2 SSD controller card is easy to install, with native OS support and no additional drivers or software required.
StarTech.com 2x M.2 SATA SSD Controller Card - PCIe - PCI Express M.2 SATA III Controller - NGFF Card Adapter (PEX2M2) - storage controller - M.2 Card / SATA 6Gb/s - PCIe 2.0 x2
Storage controller - plug-in card
Bus Type
PCIe 2.0 x2
Hard Drive Form Factor Compatibility
M.2
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
2 cm x 16.8 cm x 12 cm
60 g
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
M.2
Host Bus
PCIe 2.0 x2
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
ASMedia ASM1062
2 x M.2 Card - M.2 Card (internal)
Low-profile bracket, 2 x M.2 mounting screws
FCC, RoHS
2 cm
16.8 cm
12 cm
60 g
5 °C
50 °C
BST6 StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power In Stock £5.20
BST6 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £18.10
BST6 StarTech.com M.2 NGFF to SATA Adapter In Stock £22.45
BST6 StarTech.com M.2 SATA external SSD enclosure USB 3.0 with UASP In Stock £24.59
BST6 StarTech.com 4x M.2 to SATA 3.5in adapter In Stock £36.31
BST6 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £54.95
BST6 StarTech.com M.2 RAID Controller Card PCIe In Stock £62.82
Compatibility: PC
Stock Status: In stock
