Quicklinx: GVKZWS00 Mfr#: RACK-2U-14-BRACKET
£32.50 ex VAT
£39.00 inc VAT
The 2U 14in deep wall mounting bracket for patch panels delivers a sturdy and dependable equipment storage option, allowing you to wall mount data/IT equipment for a more efficient and accessible operating environment. It's the perfect solution for areas where space is at a premium like SoHo (small office, home office) environment, or space limited server room because it doesn't take any floor space.
  • Sturdy Construction & Easy Installation
    The mounting bracket features an all-steel design and is suitable for mounting patch panels, or other slim 19in equipment to a wall, and to organize cabling or equipment in your network closet, wiring closet, back office, or IDF. The sturdy steel construction is especially helpful for durability and stability. Also, because The open frame wall rack's mounting holes are positioned 16in. apart, allowing you a simple and secure wall-stud anchoring to your existing construction framework.
  • Includes Hardware
    M6 square cage nuts and M6 screws are included with the wall-mount bracket, additionally, M5x25 mounting screws are included to save you the hassle of sourcing separate mounting hardware. The RACK-2U-14-BRACKET is backed by a StarTech.com lifetime warranty and free lifetime technical support
StarTech.com 2U Wall Mount Rack, 19" Wall Mount Network Rack, 14 inch Deep (Low Profile), Wall Mounting Patch Panel Bracket for Network Switches, IT Equipment, 77lb (35kg) Capacity - Network Equipment Rack (RACK-2U-14-BRACKET) - network device mounting bracket - 2U - 19"
Network device mounting bracket
Placing / Mounting
Wall mountable
Package Content
Wall mount rack, 8 x M6 cage nuts, 8 x M6 cage screws, 4 x M5 x 25 mm mounting screws, 8 x plastic washers, 4 x plastic wall anchors
49.8 cm x 35.6 cm x 9.6 cm
Product Material
Steel
Height (Rack Units)
2U
Placing / Mounting
Wall mountable
Package Content
Product Material
Steel
Height (Rack Units)
2U
49.8 cm
35.6 cm
9.6 cm
Enclosure Colour
Rack Size
19"
Mounting Kit
Included
Weight Limit
35 kg
2-post, 30 cm maximum mounting depth, integrated cable management
Shipping Width
40 cm
Shipping Depth
54 cm
Shipping Height
13 cm
Limited warranty - limited lifetime warranty
GVKZ StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
GVKZ StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
