StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg
Quicklinx: 9J49WS00 Mfr#: UNISLDSHF192
Product Type: Rack shelf, Rack shelf
£122.86 ex VAT
£147.43 inc VAT
Add a vented, sliding shelf with integrated cable management into virtually any server rack or cabinet. The UNISLDSHF192 Adjustable Sliding Rack Shelf lets you add a vented, sliding shelf with cable management into virtually any 4-post server rack or cabinet. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The adjustable mounting depth design allows the shelf to be installed easily into server cabinets with mounting depths from 27.7in (702.2mm) to 31.6in (802.2mm). The sliding rails also offer a locking mechanism to stop the shelf from sliding out too far, or sliding back into the rack before maintenance is complete.
Offering a weight capacity of up to 50 lbs (22.7 kg), this sliding rack shelf features a ventilated, cold-rolled steel construction for increased airflow and durability in your server room or wiring closet installations.
For ease in routing cables neatly through your rack, a reversible cable management arm is included that can be attached to the back of the shelf, plus an adjustable bezel to keep your equipment where you want it on the shelf.
StarTech.com 2U Adjustable Vented Sliding Rack Shelf w/ Cable Management - 50lbs rack shelf - 2U
Rack shelf
Package Content
Cable management arm
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.3 cm x 60.96 cm x 8.52 cm
Sliding, adjustable depth, vented
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30
Rack shelf
Product Material
Cold-rolled steel
Package Content
Rack Size
19"
Height (Rack Units)
2U
48.3 cm
60.96 cm
8.52 cm
Weight Limit
22.7 kg
Mounting Kit
Included
RoHS, ANSI/EIA-RS-310-D
9J49 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £77.58
9J49 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £62.63
9J49 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £122.86
9J49 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £139.34
Price Range Ex VAT: 100 - 150
