Add a vented, sliding shelf with integrated cable management into virtually any server rack or cabinet. The UNISLDSHF192 Adjustable Sliding Rack Shelf lets you add a vented, sliding shelf with cable management into virtually any 4-post server rack or cabinet. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The adjustable mounting depth design allows the shelf to be installed easily into server cabinets with mounting depths from 27.7in (702.2mm) to 31.6in (802.2mm). The sliding rails also offer a locking mechanism to stop the shelf from sliding out too far, or sliding back into the rack before maintenance is complete.
Offering a weight capacity of up to 50 lbs (22.7 kg), this sliding rack shelf features a ventilated, cold-rolled steel construction for increased airflow and durability in your server room or wiring closet installations.
For ease in routing cables neatly through your rack, a reversible cable management arm is included that can be attached to the back of the shelf, plus an adjustable bezel to keep your equipment where you want it on the shelf.
- StarTech.com 2U Vented Sliding Server Rack Shelf w/ Cable Management Arm - 27.7 to 31.6in Adjustable Mounting Depth - 50lb - 24in Deep - rack shelf - 2U
- Product Type
- Rack shelf
- Package Content
- Cable management arm
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.3 cm x 60.96 cm x 8.52 cm
- Sliding, adjustable depth, vented
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Package Content
- Rack Size
- 19"
- 2U
- 48.3 cm
- 60.96 cm
- 8.52 cm
- Black
- Weight Limit
- 22.7 kg
- Mounting Kit
- Included
- RoHS, ANSI/EIA-RS-310-D
- Limited warranty: - 2 years
- Designed For
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £100.06 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £77.15 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £92.88 |
