StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg
Quicklinx: 9J5DWS00 Mfr#: UNISLDSHF19M
Product Type: Rack shelf, Rack shelf
Hurry, only 2 left in stock!
£136.75 ex VAT
£164.10 inc VAT
Add a vented, sliding shelf with integrated cable management into virtually any server rack or cabinet. The UNISLDSHF19M Adjustable Sliding Rack Shelf lets you add a vented, sliding shelf with cable management into virtually any 4-post server rack or cabinet.
The adjustable mounting depth design allows the shelf to be installed easily into server cabinets with mounting depths from 27.7in (702.2mm) to 31.6in (802.2mm). The sliding rails also offer a locking mechanism to stop the shelf from sliding out too far, or sliding back into the rack before maintenance is complete.
Offering a weight capacity of up to 125 lbs (56.7 kg), this sliding rack shelf features a ventilated, cold-rolled steel construction for increased airflow and durability in your server room or wiring closet installations.
For ease in routing cables neatly through your rack, we've included a reversible cable management arm that can be attached to the back of the shelf, plus an adjustable bezel to keep your equipment where you want it on the shelf.
StarTech.com 2U Vented Sliding Server Rack Shelf w/ Cable Management Arm - Adjustable Depth - 125lb - 19" Server Tray Shelf for Equipment Rack (UNISLDSHF19M) rack shelf - 2U
Rack shelf
Height (Rack Units)
2U
Product Material
Steel
48.3 cm x 60.96 cm x 8.52 cm
Sliding, integrated cable management, vented
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30
Rack shelf
Product Material
Steel
Height (Rack Units)
2U
48.3 cm
60.96 cm
8.52 cm
Weight Limit
56.7 kg
RoHS
9J5D StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £76.45
9J5D StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £63.41
9J5D StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.11
9J5D StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £124.40
9J5D StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £136.75
Price Range Ex VAT: 100 - 150
