Quicklinx: GTBYWS00 Mfr#: SHELF-2U-20-CENTER-V
£75.41 ex VAT
£90.49 inc VAT
2U Vented Server Rack Cabinet Shelf, 20in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 200lbs Weight Capacity - 2U Network Rack Shelf (SHELF-2U-20-CENTER-V).
  • Sturdy construction
    Crafted from SPCC cold rolled steel, this rack shelf offers durability and resilience, providing reliable support for your equipment.
  • Vented design
    The vented structure allows for optimal airflow, reducing the risk of overheating and ensuring efficient performance for all mounted devices.
  • Substantial weight capacity
    With a weight limit of 200 lbs, this shelf can securely hold various equipment types, making it suitable for a wide range of applications.
  • Compliance standards
    Designed to meet EIA-310-E and ECA-310-E standards, this rack shelf ensures compatibility with other standard rackmount equipment.
  • Complete installation kit
    The package comes with 10 plastic washers, M6 cage screws, and square cage nuts, enabling straightforward assembly and installation.
StarTech.com 2U Vented Server Rack Shelf, Center Mount 20in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment w/ Cage Nuts & Screws, 200lbs Weight Capacity - 2U Network Rack Shelf - rack shelf - 2U
Rack shelf
Package Content
10 plastic washers, 10 M6 cage screws, 10 M6 square cage nuts
Rack Size
19"
Height (Rack Units)
2U
Product Material
48.3 cm x 35.6 cm x 8.7 cm
3.2 kg
Vented
Rack shelf
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
2U
48.3 cm
35.6 cm
8.7 cm
3.2 kg
56 cm x 55 cm x 12 cm / 4.5 kg
Inner Dimensions
48.3 cm x 51.1 cm
Weight Limit
91 kg
Vented
EIA-310-E, ECA-310-E
Limited warranty: - lifetime
GTBY StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
GTBY StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.75
GTBY StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
GTBY StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
GTBY StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
GTBY StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
GTBY StarTech.com 1U Vented Shelf 12in In Stock £34.44
GTBY StarTech.com 1U Vented Shelf 20in In Stock £58.88
GTBY StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £58.56
