Quicklinx: GTBXWS00 Mfr#: SHELF-2U-14-CENTER-V
£65.65 ex VAT
£78.78 inc VAT
2U Vented Server Rack Cabinet Shelf, 14in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 200lbs Weight Capacity - 2U Network Rack Shelf (SHELF-2U-14-CENTER-V).
  • Robust construction
    Made from SPCC cold rolled steel, the server rack shelf is designed to provide durability and support for heavy equipment.
  • Optimized airflow
    The vented structure allows for efficient air circulation, helping to prevent overheating of mounted devices.
  • Compliance standards
    This rack shelf meets both EIA-310-E and ECA-310-E standards, ensuring compatibility with a variety of rack equipment.
StarTech.com 2U Vented Server Rack Shelf, Center Mount 14in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment w/ Cage Nuts & Screws, 200lbs Weight Capacity - 2U Network Rack Shelf - rack shelf - 2U
Rack shelf
Package Content
10 plastic washers, 10 M6 cage screws, 10 M6 square cage nuts
Rack Size
19"
Height (Rack Units)
2U
Product Material
48.3 cm x 35.6 cm x 8.7 cm
2.3 kg
Vented
Rack shelf
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
2U
48.3 cm
35.6 cm
8.7 cm
2.3 kg
41 cm x 55 cm x 12 cm / 3.3 kg
Inner Dimensions
48.3 cm x 34.9 cm
Weight Limit
91 kg
Vented
EIA-310-E, ECA-310-E
Limited warranty: - lifetime
GTBX StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
GTBX StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.75
GTBX StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
GTBX StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
GTBX StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
GTBX StarTech.com 1U Vented Shelf 12in In Stock £34.44
GTBX StarTech.com 1U Vented Shelf 20in In Stock £58.88
GTBX StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £58.56
