2U Vented Server Rack Cabinet Shelf, 14in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 200lbs Weight Capacity - 2U Network Rack Shelf (SHELF-2U-14-CENTER-V).
Robust construction
Made from SPCC cold rolled steel, the server rack shelf is designed to provide durability and support for heavy equipment. -
Optimized airflow
The vented structure allows for efficient air circulation, helping to prevent overheating of mounted devices. -
Compliance standards
This rack shelf meets both EIA-310-E and ECA-310-E standards, ensuring compatibility with a variety of rack equipment.
- StarTech.com 2U Vented Server Rack Shelf, Center Mount 14in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment w/ Cage Nuts & Screws, 200lbs Weight Capacity - 2U Network Rack Shelf - rack shelf - 2U
- Product Type
- Rack shelf
- Package Content
- 10 plastic washers, 10 M6 cage screws, 10 M6 square cage nuts
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- SPCC cold rolled steel
- 48.3 cm x 35.6 cm x 8.7 cm
- 2.3 kg
- Vented
- Limited lifetime warranty
- Product Type
- Rack shelf
- Product Material
- Package Content
- Rack Size
- 19"
- 2U
- 48.3 cm
- 35.6 cm
- 8.7 cm
- 2.3 kg
- Shipping Dimensions (WxDxH) / Weight
- 41 cm x 55 cm x 12 cm / 3.3 kg
- Inner Dimensions
- 48.3 cm x 34.9 cm
- Black
- Weight Limit
- 91 kg
- Vented
- EIA-310-E, ECA-310-E
- Limited warranty: - lifetime
StarTech.com 2U Vented Shelf 14in
