Quicklinx: BHZ6WS00 Mfr#: RKPNLTL2U
Product Type: Blank panel
Select:
£17.25 ex VAT
£20.70 inc VAT
Improve the organization and appearance of your rack in seconds, with a tool-less solid blanking panel. You can improve the appearance and airflow of any standard 19-inch server rack in seconds, using this 2U blanking panel. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The blanking panel creates a clean and professional look by covering empty space and visible cables. Adding blanking panels to your server racks offers a tidier appearance for a more organized server room.
For fast and easy installation, this 2U panel features a tool-less design that latches onto a standard 19 in. server rack, saving you time and hassle.
The blanking panel features a solid design that helps guide airflow down the back of your rack, rather than passing between occupied spaces. Improved airflow helps ensure your rack-mounted equipment is running at an optimal temperature.
StarTech.com Blanking Panel - 2U - 19in - Tool-less - Steel - Black - TAA Compliant - Blank Rack Panel - Filler Panel (RKPNLTL2U) - blank panel - 2U
Blank panel
Location
Front
Rack Size
19"
Height (Rack Units)
2U
Product Material
Plastic, aluminium
48.3 cm x 8.8 cm x 1.6 cm
545 g
P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK619WALL, RK619WALLGB, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Blank panel
Location
Front
Product Material
Plastic, aluminium
Rack Size
19"
Height (Rack Units)
2U
48.3 cm
8.8 cm
1.6 cm
545 g
EIA-310-D, RoHS
Limited warranty: - 2 years
BHZ6 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £9.83
BHZ6 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £13.63
