StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg
Quicklinx: 89YTWS00 Mfr#: CABSHELFHD
Product Type: Rack shelf, Rack shelf
£50.11 ex VAT
£60.13 inc VAT
Add a high-capacity fixed shelf into almost any server rack or cabinet. The CABSHELFHD 2U 18in Depth Heavy Duty Fixed Rack Mount Shelf lets you add a high-capacity 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
This high-capacity server rack shelf is constructed using 2.3mm SPCC commercial grade cold-rolled steel, providing the additional strength required to hold up to 56kg (125lbs) of equipment - a perfect solution for storing larger, non-rackmount pieces of equipment, heavy tools or peripherals in your rack or cabinet.
StarTech.com 2U Fixed Server Rack Mount Shelf, 22in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 125lbs Weight Capacity, 18" Deep - 2U Network Rack Shelf (CABSHELFHD) - rack shelf - 2U
Rack shelf
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.27 cm x 45.72 cm x 8.8 cm
4.9 kg
Cantilever
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
2U
48.27 cm
45.72 cm
8.8 cm
4.9 kg
Weight Limit
55.6 kg
Mounting Kit
Included
Cantilever
RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
89YT StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
89YT StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.85
89YT StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.09
89YT StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.55
89YT StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
89YT StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
89YT StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £71.34
89YT StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £79.75
89YT StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
89YT StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
89YT StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £35.53
89YT StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
89YT StarTech.com Vented 1U Rack Shelf - 7in In Stock £23.79
89YT StarTech.com 1U Rack Shelf - 10in In Stock £24.16
89YT StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £30.58
89YT StarTech.com Vented 1U Rack Shelf - 10in In Stock £20.23
89YT StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £38.79
89YT StarTech.com 1U Vented Shelf 12in In Stock £33.08
89YT StarTech.com 1U Vented Shelf 20in In Stock £54.90
89YT StarTech.com 2U Vented Shelf 14in In Stock £61.21
89YT StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £54.63
