The BLANKB2 2U Blank Panel is designed to EIA RS-310-C specifications and fits all 19" standard server racks and cabinets. The filler panel/blank panel is constructed of cold rolled steel and features a black powder coated finish that matches most industry standard black server cabinets and racks.
- StarTech.com 2U Blanking Panel - Steel Rack Mount Filler Panel - for 19in Server Rack Enclosure or Cabinet - Black Rack Panel (BLANKB2) - blank panel - 2U
- Product Type
- Blank panel
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.3 cm x 1.3 cm x 8.8 cm
- 0.52 kg
- Limited lifetime warranty
- Designed For
- P/N: RK1236BKF, RK2536BKF, RK4236BKB, RK619WALL, RK619WALLGB, RK960CP
- Product Type
- Blank panel
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 2U
- 48.3 cm
- 1.3 cm
- 8.8 cm
- 0.52 kg
- Black
- RoHS
- Limited warranty: - lifetime
- Designed For
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £19.93 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £100.06 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.36 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.78 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £119.59 |
StarTech.com 19in Cable Management Panel | In Stock | £22.96 |
