StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover
Quicklinx: 9TVCWS00 Mfr#: CMDUCT2U
£25.85 ex VAT
£31.02 inc VAT
Organize cables in your server rack or cabinet with a horizontal, covered cable duct. The CMDUCT2U 2U Finger Duct Cable Management Panel mounts to a standard 19" 2 or 4-post rack to help you organize horizontal cabling, through a covered cable duct.
The 2U cable organizer features a removable top cover that makes it easy to add or remove bundled cables quickly. The duct also offers a series of fingers on either side, as well as pass-through holes at the back to help you route your cables where you need them, and reduce cable strain in the process.
Made of high-quality steel, the cable manager is a durable solution for your server room or wiring closet. For easy installation, this horizontal cable organizer comes complete with 2 sets of rack screws (M5 and M6).
StarTech.com Horizontal 2U Server Rack Cable Management Finger Duct w/ Cover - 19" Network Rack Wire Duct Raceway Panel - Slotted Wire Duct (CMDUCT2U) - rack cable management panel - 2U
Rack cable management panel
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
48.2 cm x 7.9 cm x 8.81 cm
860 g
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RK1224WALHM, RK1232WALHM, RK1233BKM, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2433BKM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2
Product Material
Steel
Rack Size
19"
Height (Rack Units)
2U
48.2 cm
7.9 cm
8.81 cm
860 g
Mounting Kit
Included
RoHS
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
9TVC StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.50
9TVC StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.50
9TVC StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £20.59
9TVC StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £25.85
Product Type: Rack cable management panel
