StarTech.com 2U Hinged/Vented Rack Panel
Quicklinx: 9PRGWS00 Mfr#: RKPNLHV2U
Product Type: Blank panel
Select:
12 in stock
£19.31 ex VAT
£23.17 inc VAT
Improve the organization and appearance of your rack while maintaining easy access and airflow, with a hinged blanking panel. The RKPNLHV2U 2U Hinged & Vented Blank Rack Panel mounts to a standard 19" 2 or 4-post rack to improve the organization and appearance of your rack, while maintaining easy access and airflow.
The hinged blanking panel is reversible, meaning it can be installed to open from either the left or right side for easy access to the inside of your rack, while still covering the unused rack spaces for a professional look.
The vented rack panel is made of high-quality steel for long-term durability, plus the vented design allows for unobstructed airflow through your rack. For easy installation, this rack panel comes complete with rack installation screws (10-32).
For a non-vented panel, please see the 2U Hinged Solid Rack Blank Panel (RKPNLHS2U).
StarTech.com Blanking Panel - 2U - Vented - Hinged Rack Panel - 19in - TAA Compliant - Tool-less Installation - Filler Panel (RKPNLHV2U) - blank panel - 2U
Blank panel
Location
Front
Package Content
2 screws (10-32), 2 nuts (10-32)
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
48.2 cm x 1.5 cm x 8.81 cm
340 g
Vented panels
P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK619WALL, RK619WALLGB, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Blank panel
Location
Front
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
2U
48.2 cm
1.5 cm
8.81 cm
340 g
Vented panels
RoHS
9PRG StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £7.34
9PRG StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.94
9PRG StarTech.com 2U Hinged/Vented Rack Panel In Stock £19.31
9PRG StarTech.com 2U Hinged & Vented Blank Rack Panel In Stock £11.93
9PRG StarTech.com 2U Tool-Less Vented Blank Rack Panel In Stock £11.79
Stock Status: In stock
