Improve the organization and appearance of your rack while maintaining easy access and airflow, with a hinged blanking panel. The RKPNLHV2U 2U Hinged & Vented Blank Rack Panel mounts to a standard 19" 2 or 4-post rack to improve the organization and appearance of your rack, while maintaining easy access and airflow.
The hinged blanking panel is reversible, meaning it can be installed to open from either the left or right side for easy access to the inside of your rack, while still covering the unused rack spaces for a professional look.
The vented rack panel is made of high-quality steel for long-term durability, plus the vented design allows for unobstructed airflow through your rack. For easy installation, this rack panel comes complete with rack installation screws (10-32).
For a non-vented panel, please see the 2U Hinged Solid Rack Blank Panel (RKPNLHS2U).
- StarTech.com Blanking Panel - 2U - Vented - Hinged Rack Panel - 19in - TAA Compliant - Tool-less Installation - Filler Panel (RKPNLHV2U) - blank panel - 2U
- Product Type
- Blank panel
- Location
- Front
- Package Content
- 2 screws (10-32), 2 nuts (10-32)
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Steel
- 48.2 cm x 1.5 cm x 8.81 cm
- 340 g
- Vented panels
- 2-year warranty
- Designed For
- P/N: 2636CABINET, 7236CABINET, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALL, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK619WALL, RK619WALLGB, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Blank panel
- Location
- Front
- Product Material
- Steel
- Package Content
- Rack Size
- 19"
- 2U
- 48.2 cm
- 1.5 cm
- 8.81 cm
- 340 g
- Black
- Vented panels
- RoHS
- Limited warranty: - 2 years
- Designed For
StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £7.43 |
StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £12.34 |
StarTech.com 2U Hinged/Vented Rack Panel | In Stock | £20.05 |
