Server Rack Cable Management - 2U Horizontal - Cable Duct Raceway Panel with Cover (CMDUCT2U2).
Efficient organization
The Server Rack Cable Management - 2U Horizontal - Cable Duct Raceway Panel with Cover is designed to offer an efficient solution for organizing and protecting your cables within a 19" rack. Its horizontal orientation and 2U height make it a perfect fit for any standard server rack, ensuring a neat and orderly setup. -
Durable construction
Constructed from high-quality plastic and steel, this rack cable management panel is built to last. The inclusion of a mounting kit facilitates easy installation, while its compliance with REACH and RoHS standards ensures a product that not only meets high durability standards but also adheres to strict environmental regulations.
- StarTech.com Server Rack Cable Management - 2U Horizontal - Cable Duct Raceway Panel with Cover (CMDUCT2U2) - rack cable management panel - 2U
- Product Type
- Rack cable management panel
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Plastic, steel
- 7.2 cm x 48.3 cm x 8.8 cm
- Horizontal orientation
- 2-year warranty
- Product Type
- Product Material
- Plastic, steel
- Rack Size
- 19"
- 2U
- 7.2 cm
- 48.3 cm
- 8.8 cm
- Shipping Dimensions (WxDxH) / Weight
- 54.5 cm x 15 cm x 14.5 cm / 1.5 kg
- Black
- Mounting Kit
- Included
- RoHS, REACH
- Limited warranty: - 2 years
