Increase peripheral and equipment accessibility with this vented sliding cabinet shelf. The UNISLDSHF19 19in Vented Adjustable Mounting Depth Sliding Server Rack Cabinet Shelf offers a simple way to install non rack mountable equipment into a server cabinet or open server rack. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Offering a weight capacity of up to 50 lbs (22.7 kg), the sliding rack shelf features a ventilated, cold-rolled steel shelf on two locking adjustable rails which allow the shelf to be installed into cabinets or racks with mounting depths from 20in (510mm) to 30in (744mm). The locking feature locks the shelf 3/4 of the way out, preventing the shelf from accidentally falling out of the rack or sliding back in before maintenance is complete.
Durable construction
Made from cold-rolled steel, this rack shelf offers support for heavy equipment while ensuring longevity. -
Adjustable depth
The depth of the shelf can be adjusted from 20 to 30 inches, allowing it to fit various rack setups and accommodate equipment of different sizes. -
Secure design
With a lockable feature, this shelf ensures that equipment remains stable and secure during operation. -
Effective ventilation
The vented design aids in airflow, helping to keep equipment cool and functioning efficiently. -
Standard fit
Designed for 19-inch racks, this 2U shelf integrates easily into existing server setups without complications.
- StarTech.com Server Rack Shelf - 2U - 20 to 30in Adjustable Mounting Depth - Vented - Server Rack Cabinet Shelf - 24in Deep - rack shelf - 1U
- Product Type
- Rack shelf
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- Cold-rolled steel
- Sliding, adjustable depth, lockable, vented
- Designed For
- P/N: 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1219SIDEM, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK960CP, RKQMCAB12
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 1U
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK960CP, RKQMCAB12
