StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: 887LWS00 Mfr#: CABSHELF22V
13 In Stock
£44.28 ex VAT
£53.13 inc VAT
Add a sturdy, 22in depth vented shelf into almost any server rack or cabinet. The CABSHELF22V 2U 22in Depth Vented Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The vented rack shelves improve air flow and help to lower temperatures in the rack. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
  • Strong construction
    Made from high-quality steel, this rack shelf provides durability, making it capable of holding various equipment securely.
  • Vented design
    The vented feature allows for improved airflow, aiding in the cooling of mounted devices and enhancing performance.
  • Easy installation
    The included mounting kit ensures simple and quick installation, allowing for efficient use of space in server racks.
  • Environmentally friendly
    Compliant with RoHS standards, this product supports environmentally responsible practices while maintaining quality.
  • Ample weight capacity
    Designed to support a weight limit of 22.6 kg, this shelf is suitable for both light and moderately heavy equipment.
StarTech.com 1U Server Rack Shelf, 2U 22in Universal Fixed Vented Network Rack Shelf/Cantilever Tray for 19" AV/Data/Network Equipment Enclosure w/Cage Nuts & Screws, 50lbs Weight Cap. - 2U Network Rack Shelf (CABSHELF22V) - rack shelf - 2U
Rack shelf
Rack Size
22"
Height (Rack Units)
2U
Product Material
Steel
48.27 cm x 55.88 cm x 8.8 cm
3.6 kg
Vented
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP
Rack shelf
Product Material
Steel
Rack Size
22"
Height (Rack Units)
2U
48.27 cm
55.88 cm
8.8 cm
3.6 kg
Weight Limit
22.6 kg
Mounting Kit
Included
Vented
RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP
