StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket
Quicklinx: 6B9TWS00 Mfr#: RK219WALLV
Product Type: Mounting bracket
£35.52 ex VAT
£42.62 inc VAT
Mount a server, network or telecommunications device vertically with this 2U wall-mountable rack. The RK219WALLV 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket offers a versatile storage solution allowing rackmount equipment (Network devices, power strips, patch panels) to be mounted vertically (flush with wall) to save space. Alternatively, the 2U bracket can be installed horizontally under a desk, making it easy to access installed equipment directly from your workspace. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Perfect for SoHo (small office, home office) environments, the wallmount bracket features a sturdy steel design constructed to EIA-310 19in rack standards, and offers space-savings for environments lacking the footprint space for a full size server equipment rack. Suitable for mounting on virtually any wall/ceiling surface (e.g. drywall), the bracket mounting holes are positioned at exactly 16in apart, matching standard construction framework.
Need more storage space? StarTech.com also offers a RK319WALLV 3U 19in Wallmount Bracket and a RK419WALLV 4U 19in Wallmount Bracket.
  • Durable steel construction
    The bracket is made of high-quality steel, providing strength and longevity to support various networking components.
  • Space-saving design
    This wall-mountable bracket allows for efficient use of available space, ideal for compact networking setups.
  • Complete mounting kit included
    Every purchase comes with a mounting kit, ensuring that all necessary hardware is available for installation.
  • Standard rack compatibility
    Designed for 19" rack sizes, this bracket integrates with existing network infrastructure.
  • Compliance with safety standards
    This product adheres to UL and RoHS standards, meeting safety and environmental requirements.
StarTech.com 2U Vertical Wall Mount Patch Panel Bracket - Steel Rack Mount Bracket w/Hardware for 19" Network, Server and Data Equipment (RK219WALLV) - mounting bracket - 2U
Mounting bracket
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
5.04 cm x 10.45 cm x 15.1 cm
0.8 kg
P/N: SV831DUSBUK
Mounting bracket
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
2U
5.04 cm
10.45 cm
15.1 cm
0.8 kg
Mounting Kit
Included
UL, RoHS
Limited warranty: - lifetime
P/N: SV831DUSBUK
6B9T StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
6B9T StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
6B9T StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
6B9T StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
6B9T StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
6B9T StarTech.com 1U 19in Hinged Wall Mounting Bracket for Patch Panels In Stock £16.64
6B9T StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
6B9T StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
6B9T StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
6B9T StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
6B9T StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
6B9T StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
6B9T StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
6B9T StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
6B9T StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
6B9T StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
6B9T StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
6B9T StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
6B9T StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
6B9T StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
6B9T StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
6B9T StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
6B9T StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
6B9T Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
6B9T StarTech.com 19in Cable Management Panel In Stock £24.18
6B9T StarTech.com 4U WM Server Rack with Shelf In Stock £105.68
6B9T StarTech.com 8U WM Server Rack with Shelf In Stock £140.13
6B9T StarTech.com 6U Wall Mount Rack Bracket In Stock £67.43
6B9T StarTech.com 18U Server Rack Enclosure In Stock £379.01
6B9T StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
6B9T StarTech.com 26U Server Rack Enclosure In Stock £475.05
6B9T StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
6B9T StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
6B9T StarTech.com 12U Server Rack Enclosure In Stock £338.60
6B9T StarTech.com 12U Server Rack Enclosure In Stock £283.26
6B9T StarTech.com 15U Server Rack Enclosure In Stock £320.92
6B9T StarTech.com 12U Server Rack Enclosure In Stock £385.18
6B9T StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
