StarTech.com 2U 19in Steel Horizontal Wall Mountable Server Rack
Quicklinx: 7P1BWS00 Mfr#: RK219WALVO
Vertically mount your server or networking equipment to a wall, in this low-profile cabinet. The RK219WALVO 2U 19-inch Steel Side Mount Rack is a Wall Mountable Server Rack that provides a robust solution for mounting your telecom, network or server equipment.
This 2U rack can be mounted to a wall or directly under a desk/table, expanding your workspace and keeping equipment easily accessible.
Perfect for SOHO (Small Office, Home Office) environments, the wallmount rack offers a space-saving installation for environments lacking the footprint space for a full-size server equipment rack. The rack allows your equipment to be mounted vertically - non-rackmount equipment can be installed using the rack as a wall case/chassis.
Constructed to EIA-RS310 19-inch rack standards, the RK219WALVO features a sturdy steel design.
StarTech.com 2U Vertical Wall Mount Mount Server Rack - Low-profile 2 Post Server Cabinet for Switch, Router or Network Equipment - 61.2 lbs capacity (RK219WALVO) - rack - 2U
Rack
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
11.8 cm x 50.5 cm x 55.3 cm
8 kg
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
2U
11.8 cm
50.5 cm
55.3 cm
8 kg
Weight Limit
27.7 kg
Mounting Kit
Included
RoHS
Limited warranty: - lifetime
7P1B StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.68
7P1B StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
7P1B StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £40.62
7P1B StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £54.82
7P1B StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7P1B StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
7P1B StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7P1B StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7P1B StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
7P1B StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
7P1B StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
7P1B StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
7P1B StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
7P1B StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
7P1B StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
7P1B StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
7P1B StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
7P1B StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
7P1B StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
7P1B StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
7P1B StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
7P1B Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
7P1B StarTech.com 19in Cable Management Panel In Stock £24.18
7P1B StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
