StarTech.com 2U 19in Hinged Wall Mount Bracket for Patch Panels
Quicklinx: 7B8DWS00 Mfr#: WALLMOUNTH2
Product Type: Wall mount bracket
Hurry, only 3 left in stock!
£17.31 ex VAT
£20.77 inc VAT
Wall mount a patch panel or network switch while providing hinged access to the back of the device(s). The WALLMOUNTH2 2U 19in Hinged Wall Mounting Bracket for Patch Panels is 6in deep and sturdily designed to provide a dependable solution for mounting a patch panel, or other slim 19in networking equipment to a wall.
The patch panel wall mount features a hinged design for easy access to configuration buttons, ports and cables.
StarTech.com 2U Hinged Wall Mount Patch Panel Bracket - 6 inch Deep - 19" Patch Panel Swing Rack for Shallow Network Equipment- 22lbs (WALLMOUNTH2) - wall mount bracket - 2U - 19"
Wall mount bracket
10.2 cm x 8.9 cm
Product Material
Steel
Height (Rack Units)
2U
Wall mount bracket
Product Material
Steel
Height (Rack Units)
2U
10.2 cm
8.9 cm
Rack Size
19"
7B8D StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.68
7B8D StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
7B8D StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
7B8D StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £40.62
7B8D StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £54.82
7B8D StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
7B8D StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7B8D StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
7B8D StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7B8D StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7B8D StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
7B8D StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
7B8D StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
7B8D StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
7B8D StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
7B8D StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
7B8D StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
7B8D StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
7B8D StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
7B8D StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
7B8D StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
7B8D StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
7B8D Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
7B8D StarTech.com 2-Post Desktop Rack - 8U In Stock £35.14
7B8D StarTech.com 18U Server Rack Enclosure In Stock £379.01
7B8D StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
7B8D StarTech.com 26U Server Rack Enclosure In Stock £475.05
7B8D StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
7B8D StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
7B8D StarTech.com 12U Server Rack Enclosure In Stock £338.60
7B8D StarTech.com 12U Server Rack Enclosure In Stock £283.26
7B8D StarTech.com 15U Server Rack Enclosure In Stock £320.92
7B8D StarTech.com 12U Server Rack Enclosure In Stock £385.18
7B8D StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
7B8D StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
