StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg
Quicklinx: 887NWS00 Mfr#: CABSHELFV
Product Type: Rack shelf, Rack shelf
10 In Stock
£37.00 ex VAT
£44.40 inc VAT
Add a sturdy, vented shelf into almost any server rack or cabinet. The CABSHELFV 2U 16in Depth Universal Vented Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Our vented rack shelves improve air flow and help to lower temperatures in the rack. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
  • Durable construction
    The 1U Server Rack Shelf is made from cold-rolled steel, providing robust support for various equipment while ensuring long-lasting performance.
  • Efficient airflow
    With its vented design, this shelf promotes air circulation around your devices, helping to prevent overheating and maintain optimal performance.
  • Easy installation
    The shelf comes with a mounting kit, allowing for straightforward installation on standard 19-inch racks, facilitating quick setups.
StarTech.com 1U Server Rack Shelf, 2U 16in Universal Fixed Vented Network Rack Shelf/Cantilever Tray for 19" AV/Data/Network Equipment Enclosure w/Cage Nuts & Screws, 50lbs Weight Cap. - 2U Network Rack Shelf (CABSHELFV) - rack shelf - 2U
Rack shelf
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.27 cm x 40.64 cm x 8.8 cm
2.6 kg
Vented, cantilever
P/N: 2POSTRACK12, 2POSTRACK16, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
2U
48.27 cm
40.64 cm
8.8 cm
2.6 kg
Weight Limit
22.6 kg
Mounting Kit
Included
Vented, cantilever
RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
887N StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
887N StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
887N StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
887N StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
887N StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
887N StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
887N StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
887N StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
887N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
887N StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
887N StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
887N StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
887N StarTech.com Vented 1U Rack Shelf - 7in In Stock £24.38
887N StarTech.com 1U Rack Shelf - 10in In Stock £25.16
887N StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
887N StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
887N StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.75
887N StarTech.com 1U Vented Shelf 12in In Stock £34.44
887N StarTech.com 1U Vented Shelf 20in In Stock £56.28
887N StarTech.com 2U Vented Shelf 14in In Stock £62.75
887N StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £55.99
