Add two RS232 Serial Ports, and one Parallel Port to an Embedded System, through a mini PCI-Express Slot.
The MPEX2S1P552 2S1P Mini PCI Express Serial/Parallel Combo Card turns a mini-PCIe slot into two RS232 (DB9) serial ports, and one IEEE 1284 parallel port - a cost-saving solution for adding serial and parallel support to embedded systems that lack built-in serial/parallel functionality.
The 16650 UART adapter card features a native PCI Express single chip design, which enables you to take advantage of full PCI Express capability, by providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional "bridge chip" serial cards .
- StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card for Embedded Systems - parallel/serial adapter - Mini PCI Express - 2 ports
- Parallel/serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- Mini PCI Express
- PCI Specification Revision
- PCIe 1.1
- 3 cm x 5 cm x 1 cm
- 150 g
- Ports Qty
- 2 ports
- Auxiliary Ports
- 1 x parallel port
- Data Link Protocol
- Parallel, serial
- Data Transfer Rate
- 1.5 Mbps
- Processor
- MosChip Semiconductor MCS9901CV-CC
- System Requirements
- Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
- Limited lifetime warranty
- Parallel/serial adapter - 2 ports
- Form Factor
- Plug-in card
- Mini PCI Express
- PCIe 1.1
- Connectivity Technology
- Wired
- Parallel, serial
- Auxiliary Ports
- 1 x parallel port
- 1.5 Mbps
Processor / Memory
- Processor
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x Mini PCI Express - full-length
- FCC, RoHS
- OS Required
- 3 cm
- 5 cm
- 1 cm
- 150 g
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 6ft Straight Through Serial Cable - DB9 M/F | In Stock | £3.53 |
StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter | In Stock | £17.25 |
StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter | In Stock | £35.24 |
StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card for Embedded Systems | In Stock | £24.87 |
StarTech.com 4 Port RS232 Mini PCI Express Serial Card with 16650 UART | In Stock | £65.96 |
