Product
StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART
Quicklinx: 76T4WS00 Mfr#: PEX2S5531P
Type: Parallel/serial adapter
Compatibility: PC
Interface: PCI Express
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£22.25 ex VAT
£26.70 inc VAT
Express delivery Delivered on Tuesday
The PEX2S5531P 2S1P PCI Express card turns a PCI Express slot into two RS232 (DB9) serial ports and one parallel port. The adapter card features a native PCI Express single chip design that allows you to take advantage of full PCI Express capability, providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional serial cards which use a bridge chip design.
Compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64-bit), Linux Kernel 2.6.11 and up, and MAC OS 10.4, this 2 port serial 1 port parallel PCI-Express card also features an optional low profile/half-height bracket that allows the card to be installed in virtually any computer case, regardless of the case form factor.
This product is a replacement for the PEX2S5521P card.
StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART - parallel/serial adapter
Plug-in card
Interface (Bus) Type
PCI Express
12 cm x 10.5 cm x 2 cm
140 g
Cabling Type
Serial RS-232
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Apple MacOS X 10.x, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Plug-in card
PCI Express
Wired
Cabling Type
Serial RS-232
2 x RS-232 - 9 pin D-Sub (DB-9) , 1 - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI Express
FCC, RoHS
12 cm
10.5 cm
2 cm
140 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
Compatibility: PC
Price Range Ex VAT: 0 - 50
