StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART
Quicklinx: 76T4WS00 Mfr#: PEX2S5531P
Type: Parallel/serial adapter
Compatibility: PC
Interface: PCI Express
  • Windows 8 (32/64 bits)
£29.47 ex VAT
£35.36 inc VAT
The PEX2S5531P 2S1P PCI Express card turns a PCI Express slot into two RS232 (DB9) serial ports and one parallel port. The adapter card features a native PCI Express single chip design that allows you to take advantage of full PCI Express capability, providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional serial cards which use a bridge chip design.
Compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64-bit), Linux Kernel 2.6.11 and up, and MAC OS 10.4, this 2 port serial 1 port parallel PCI-Express card also features an optional low profile/half-height bracket that allows the card to be installed in virtually any computer case, regardless of the case form factor.
This product is a replacement for the PEX2S5521P card.
  • Robust connectivity options
    Equipped with two RS-232 serial ports and one parallel port, this adapter facilitates connections with a variety of devices, ensuring compatibility with older hardware.
  • High-performance PCI Express interface
    The PCIe design allows for fast data transfer rates and efficient utilization of system resources while being easy to install and manage.
  • Broad operational range
    This card can function reliably in extreme temperatures from -20°C to 85°C, making it suitable for various environments and applications.
  • Compliance with industry standards
    The product meets rigorous FCC and RoHS regulations, ensuring it adheres to safety and environmental guidelines.
  • Wired connectivity reliability
    Utilizing wired connectivity technology ensures stable and consistent connections, minimizing the chances of data loss during transmission.
StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART - PCIe 2x Serial 1x Parallel RS232 Adapter Card (PEX2S5531P) - parallel/serial adapter - PCIe
Plug-in card
Interface (Bus) Type
PCI Express
12 cm x 10.5 cm x 2 cm
140 g
Cabling Type
Serial RS-232
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Apple MacOS X 10.x, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Plug-in card
PCI Express
Wired
Cabling Type
Serial RS-232
2 x RS-232 - 9 pin D-Sub (DB-9) , 1 - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI Express
FCC, RoHS
12 cm
10.5 cm
2 cm
140 g
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
76T4 StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART In Stock £70.69
76T4 StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £35.73
76T4 StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £151.41
76T4 StarTech.com 1-Prt PCI Express Serial Card In Stock £36.65
76T4 StarTech.com PCIe Dual Serial Port Card In Stock £41.75
Compatibility: PC
