StarTech.com 2Pt USB 3.1 Gen 2 Card -10Gbps
Quicklinx: BL6YWS00 Mfr#: PEXUSB312A
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Upgrade your computer to the faster speed of USB 3.1, by adding two 10Gbps USB Type-A ports. This USB 3.1 Gen 2 card prepares you for the next generation of USB performance, adding two USB-A ports to your desktop with a combined bandwidth up to 10Gbps. Now you can access USB 3.1 Gen 2 peripherals at twice the speed of traditional USB 3.0 (USB 3.1 Gen 1) devices.
With greater bandwidth you can save time and avoid the performance bottlenecks often associated with other connectivity technologies.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2 and rest assured you're ready for both current and future high-bandwidth USB-A devices.
With higher data throughput, this PCI Express USB 3.1 card is a necessity for external hard drives, , and many other USB 3.1 peripherals. Plus, the USB card integrates a SATA power connector to support high-powered devices, making it ideal for use with large external storage solutions.
For more flexibility, you can couple the card with a USB31AC1M USB-C to USB-A Cable (USB31AC1M) and connect your USB Type-C devices.
Connecting older peripherals isn't a problem. This versatile USB 3.1 card is backward compatible with legacy USB 3.0/2.0 devices that use the common USB Type-A port, so you can eliminate the added expense and aggravation of purchasing new devices.
The USB 3.1 Gen 2 card offers hassle-free installation with no additional software or drivers required in natively supported Windows 10, 8.1, and 8 operating systems. Plus, the high-quality card includes both standard-profile and low-profile/half-height brackets, making it easy to install in full or small form-factor PCs or servers.
StarTech.com 2 Port USB 3.1 Gen 2 (10Gbps) Card - 2x USB-A - PCIe - UASP - USB adapter - PCIe 3.0 x4 - USB 3.1 x 2
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
USB 3.1 x 2
1.8 cm x 9 cm x 12 cm
50 g
USB, USB 2.0, USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
ASMedia ASM1142
USB 1.1, USB 2.0, USB 3.0, xHCI, USB 3.1
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
P/N: S251BMU313, S251BPU313, S351BU313, S352BU313R, SMS1BMU313, USB312SAT3, USB31C2SAT3
USB adapter
PCI Express 3.0 x4
Ports
USB 3.1 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0, USB 3.1
Data Transfer Rate
10 Gbps
UASP
Processor / Memory
ASMedia ASM1142
2 x USB 3.1 - 9 pin USB Type A (external)
Low-profile bracket
MTBF
50,000 hour(s)
FCC, RoHS
1.8 cm
9 cm
12 cm
50 g
70 °C
5 - 95%
BL6Y StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
BL6Y StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.00
BL6Y StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.45
BL6Y StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £62.29
BL6Y StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £26.43
BL6Y StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
