Add an internal SATA port and an external SATA (eSATA) port to your desktop computer through a PCI Express expansion slot. This PCI Express SATA Controller Card allows you to turn a PCI Express (1x) slot into one internal SATA and one external SATA (eSATA) connection. Supporting SATA 300 (SATA II) hard drives and data transfer rates of up to 3Gbps, this controller card is the perfect solution if you need an extra SATA port or want to externalize your storage.
The controller card is designed based on a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for your external storage needs. Plus, PEXESATA2I features Port Multiplier support with command based switching for connecting multiple external hard drives to host PC or Mac Desktop through one eSATA connection.
- StarTech.com 1 Port eSATA + 1 Port SATA PCI Express SATA Controller Card - storage controller (RAID) - SATA 3Gb/s / eSATA 3Gb/s - PCIe x1
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe x1
- Interface
- Data Transfer Rate
- 3 Gbit/s
- Supported Devices
- Hard drive, disk array (RAID)
- Channel Qty
- 2
- Max Storage Devices Qty
- 2
- RAID Level
- JBOD
- System Requirements
- Microsoft Windows Vista / 2000 / XP
- 12 cm x 10.2 cm x 2 cm
- 44 g
- Limited lifetime warranty
- Designed For
- P/N: S3540BU33E
- Host Bus
- PCIe x1
Storage Controller
- Interface
- 3 Gbit/s
- Supported Devices
- Channel Qty
- 2
- 2
- RAID Level
- JBOD
- Processor
- JMicron JMB363
- 1 x SATA 3Gb/s - eSATA (external) , 1 x SATA 3Gb/s - SATA (internal)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- 12 cm
- 10.2 cm
- 2 cm
- 44 g
- Designed For
- P/N: S3540BU33E
