Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC2MYL Cat 6 Patch Cable (2m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Strong performance
The cable supports a tested frequency of up to 500 MHz, suitable for high-bandwidth applications, ensuring quick and efficient data transmission. -
Snagless design
Featuring snagless connectors, this cable prevents damage during installation, allowing for hassle-free setup without worrying about connector breakage. -
Reliable connectivity
Designed to minimize Near-End Crosstalk (NEXT), this cable provides a stable connection, enhancing overall network performance and reliability. -
Durable construction
The PVC jacket protects the cable and ensures flexibility and longevity, making it an ideal choice for various environments. -
Compliant standards
This cable meets RoHS and ETL standards, indicating its safety and suitability for use in networking applications, adhering to environmental regulations.
- StarTech.com 2m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC2MYL) - patch cable - 2 m - yellow
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 2 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 2 m
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL - up to 500 MHz
StarTech.com 2m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable
