StarTech.com 2m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9KMVWS00 Mfr#: N6PATC2MYL
Length: 2m
Colour: Yellow
More than 50 In Stock
£4.36 ex VAT
£5.23 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC2MYL Cat 6 Patch Cable (2m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Strong performance
    The cable supports a tested frequency of up to 500 MHz, suitable for high-bandwidth applications, ensuring quick and efficient data transmission.
  • Snagless design
    Featuring snagless connectors, this cable prevents damage during installation, allowing for hassle-free setup without worrying about connector breakage.
  • Reliable connectivity
    Designed to minimize Near-End Crosstalk (NEXT), this cable provides a stable connection, enhancing overall network performance and reliability.
  • Durable construction
    The PVC jacket protects the cable and ensures flexibility and longevity, making it an ideal choice for various environments.
  • Compliant standards
    This cable meets RoHS and ETL standards, indicating its safety and suitability for use in networking applications, adhering to environmental regulations.
StarTech.com 2m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC2MYL) - patch cable - 2 m - yellow
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
9KMV StarTech.com 2m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.36
9KMV StarTech.com 2m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.36
9KMV StarTech.com 2m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.36
9KMV StarTech.com 2m Green Cat6 Patch Cable In Stock £4.36
9KMV StarTech.com 2m Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.36
9KMV StarTech.com 2m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.22
Length: 2m
Colour: Yellow
