StarTech.com 2m Yellow Cat 5e Patch Cable
Quicklinx: B2VYWS00 Mfr#: 45PAT2MYL
Length: 2m
Colour: Yellow
More than 50 in stock
£2.94 ex VAT
£3.52 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PAT2MYL Cat5e patch cable (2m) meets or exceeds all Cat 5e cable specifications to ensure reliable Ethernet network connections, and features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 5e cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 2m Yellow Cat5e / Cat 5 Snagless Patch Cable - patch cable - 2 m - yellow
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Molded, snagless, minimised Near-End Crosstalk (NEXT)
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
B2VY StarTech.com 2m Blue Cat 5e Patch Cable In Stock £2.94
B2VY StarTech.com 2m Black Cat 5e Patch Cable In Stock £2.96
B2VY StarTech.com 2m Green Cat 5e Patch Cable In Stock £2.94
B2VY StarTech.com 2m Red Cat 5e Patch Cable In Stock £2.94
B2VY StarTech.com 2m Grey Cat 5e Patch Cable In Stock £2.94
B2VY StarTech.com 2m Orange Cat 5e Patch Cable In Stock £2.96
B2VY StarTech.com 2m Yellow Cat 5e Patch Cable In Stock £2.94
B2VY StarTech.com 2m White Cat 5e Patch Cable In Stock £2.95
Length: 2m
Colour: Yellow
Price Range Ex VAT: 0 - 50
