StarTech.com 2m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 9KMLWS00 Mfr#: N6PATC2MWH
Length: 2m
Colour: White
16 In Stock
£4.19 ex VAT
£5.02 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC2MWH Cat 6 Patch Cable (2m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Efficient data transfer
    This cable supports a tested frequency of up to 500 MHz, allowing for efficient data transfer and high-speed networking suitable for digital tasks.
  • Robust construction
    Crafted with a durable PVC jacket, this Ethernet cable is built to withstand wear while maintaining optimal performance.
  • Secure connection
    Equipped with gold-plated RJ-45 connectors, this cable ensures a secure connection that enhances signal quality and minimizes loss.
  • System compatibility
    This patch cable uses the T568B wiring scheme, making it compatible with a wide range of networking equipment.
  • Interference reduction
    Designed with minimized Near-End Crosstalk (NEXT), this cable effectively reduces interference and ensures a clearer data signal during transmission.
StarTech.com 2m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC2MWH) - patch cable - 2 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
9KML StarTech.com 2m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.19
9KML StarTech.com 2m Orange Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.15
9KML StarTech.com 2m Green Cat6 Patch Cable In Stock £4.15
9KML StarTech.com 2m Purple Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.39
9KML StarTech.com 2m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.19
Length: 2m
Colour: White
