StarTech.com 2m USB to Lightning Cable - Black
Quicklinx: F2HQWS00 Mfr#: RUSBLTMM2MB
Length: 2m
20 in stock
£14.03 ex VAT
£16.83 inc VAT
Express delivery Delivered on Tuesday
This USB to Lightning cable withstands the daily demands of charging and syncing your mobile devices. Tested to endure strenuous wear and tear, and winter and summer in-car use, the rugged cable is a must-have for both business and consumer applications.
The longer cable is ideal for overcoming distance restrictions.
The durable Lightning cable has a Dupont Kevlar reinforcement that shelters it from the stress of frequent bends and twists. This also lets the cable flex without over-stretching and strengthens the core of the cable.
Cable Key Features.
Kevlar aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly.
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features.
Lightning connector provides 12W for charging your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
StarTech.com 2m USB A to Lightning Cable - Durable Rugged Black iPhone iPad Charge & Sync Charger Cord w/Aramid Fiber Apple MFI Certified - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
American Wire Gauge (AWG)
22/32
Length
2 m
Connector
USB - male - straight
Connector (Second End)
Lightning - male - straight
DuPont Kevlar reinforced core, strain relief
Apple 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod nano (7G); iPod touch (5G, 6G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
22/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
2 m
Plated Connector
Nickel
Connector
4 pin USB Type A - male - straight
Apple Lightning - male - straight
MFI
Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
F2HQ StarTech.com 1m USB to Lightning Cable In Stock £11.53
F2HQ StarTech.com 1m USB to Lightning Cable - Black In Stock £11.50
F2HQ StarTech.com 2m USB to Lightning Cable In Stock £13.93
F2HQ StarTech.com 2m USB to Lightning Cable - Black In Stock £14.03
Length: 2m
Price Range Ex VAT: 0 - 50
