StarTech.com 2m USB to Lightning Cable - Black
Quicklinx: F2HQWS00 Mfr#: RUSBLTMM2MB
This USB to Lightning cable withstands the daily demands of charging and syncing your mobile devices. Tested to endure strenuous wear and tear, and winter and summer in-car use, the rugged cable is a must-have for both business and consumer applications.
The longer cable is ideal for overcoming distance restrictions.
The durable Lightning cable has a Dupont Kevlar reinforcement that shelters it from the stress of frequent bends and twists. This also lets the cable flex without over-stretching and strengthens the core of the cable.
Cable Key Features.
Kevlar aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil with braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable and environmentally friendly.
The cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle. Plus, the improved inner molding resists cracking and reduces cable damage.
Connector Key Features.
Lightning connector provides 12W for charging your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
  • Durable construction
    The cable features double shielded technology, providing a reliable connection and minimizing interference for optimal performance.
  • High-quality connectors
    Both connectors are designed with a straight design and plated with nickel, enhancing durability and ensuring a secure connection.
  • Flexible and resilient jacket
    Made with thermoplastic elastomer (TPE), the jacket offers flexibility and resistance to wear, making it ideal for everyday use.
  • MFi certified
    This cable meets Apple’s MFi standards, ensuring compatibility and safe charging for all your Apple devices.
  • Added strain relief
    The strain relief feature helps prevent damage at the connectors, extending the lifespan of the cable and maintaining performance.
StarTech.com 6 ft(2m) Durable Black USB-A to Lightning Cable, Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charger/Sync Power Cord, Apple MFi Certified iPad/iPhone 12 Pro Max - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
American Wire Gauge (AWG)
22/32
Length
2 m
Connector
USB - male - straight
Connector (Second End)
Lightning - male - straight
Strain relief
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
22/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
2 m
Plated Connector
Nickel
Strain relief
Connector
4 pin USB Type A - male - straight
Apple Lightning - male - straight
MFI
F2HQ StarTech.com 1m USB to Lightning Cable In Stock £12.30
F2HQ StarTech.com 1m USB to Lightning Cable - Black In Stock £12.30
F2HQ StarTech.com 1m / 3.3ft Angled Lightning to USB Cable In Stock £13.47
F2HQ StarTech.com 2m / 6.6ft Angled Lightning to USB Cable - Black In Stock £14.19
