StarTech.com 2m USB-C to VGA Cable
Quicklinx: CHN5WS00 Mfr#: CDP2VGAMM2MB
10 In Stock
£21.96 ex VAT
£26.35 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to a VGA display without additional adapters. This USB-C to VGA adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your VGA monitor, television or projector.
The adapter supports a connection distance of up to 2 m (6 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 2 m (6 ft.) in length, the adapter cable delivers a direct connection between your USB-C device and your VGA monitor. This means you don't have to use additional adapters or cabling, which helps ensure a tidy and professional installation. For shorter installations, a 1 m (3 ft.) USB-C to VGA cable enable you to choose the right cable length for your custom installation needs.
The USB-C to VGA adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
The adapter harnesses the video capabilities that are built into your USB Type-C connector to deliver video resolutions up to 1920x1200 and 1080p, providing full high-definition support for your high-resolution VGA monitors. it's a great accessory for multitasking on high-resolution VGA displays at home, in the office or other HD work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
StarTech.com 6ft (2m) USB C to VGA Cable, 1920x1200/1080p USB Type C to VGA Video Active Adapter Cable, Thunderbolt 3 Compatible, Laptop to VGA Monitor/Projector, DP Alt Mode HBR2 Cable - 2m USB-C Video Cable (CDP2VGAMM2MB) - video / USB cable - 24 pin USB-C to HD-15 (VGA) - 2 m
Video / USB cable
1920 x 1200 (WUXGA) support, HBR2 support, DisplayPort Alternate Mode support
Length
2 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - male (output)
Displayport 1.2/Thunderbolt 3
3-year warranty
P/N: TB4CDOCK
Video / USB cable
Length
2 m
132 g
Connector
Displayport 1.2/Thunderbolt 3, FCC, RoHS
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
3.2 cm
Shipping Weight
138 g
3-year warranty
P/N: TB4CDOCK
CHN5 StarTech.com USB-C to HDMI Adapter In Stock £15.52
CHN5 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.64
CHN5 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £18.73
CHN5 StarTech.com 2m USB-C to DVI Cable In Stock £23.46
CHN5 StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
CHN5 StarTech.com 1m USB-C to DVI Cable In Stock £11.22
CHN5 StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
CHN5 StarTech.com 1m USB-C to VGA Cable In Stock £19.38
CHN5 StarTech.com 2m USB-C to VGA Cable In Stock £21.96
CHN5 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
CHN5 StarTech.com 6 ft USB C to DP Cable - White In Stock £9.11
CHN5 StarTech.com 3m USB C to DisplayPort Cable - White In Stock £20.18
CHN5 StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £26.32
CHN5 StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £9.72
CHN5 StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.26
CHN5 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.04
CHN5 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £23.05
CHN5 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
CHN5 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
CHN5 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
CHN5 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.97
CHN5 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £28.47
CHN5 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £31.29
