StarTech.com 2m USB-C Charging Cable
Quicklinx: HM0ZWS00 Mfr#: USB2CC2MNC
Length: 2m
£5.94 ex VAT
£7.12 inc VAT
Seamlessly charge a USB Type-C mobile device or transfer files to a USB-C host computer with this high-quality USB-C cable. The USB-C charger cord facilitates up to 60W Power Delivery and 3A output for fast charging. It supports USB 2.0 (480Mbps) transfer rates and is suitable for general use.
Quality Construction
Designed for frequent charging, the USB-C Charger Cable features a rugged TPE outer jacket for increased wear resistance. Its flexible strain relief and nickel-plated connectors are designed to withstand over 10,000 insertion cycles, enhancing its durability and longevity.
Charge Mobile Devices On The Go
Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 1m (3.3ft) USB Type-C cable is the ideal length for desk workstations, commuters, in-car use or to reduce clutter when syncing with a USB-C laptop.
Power a Laptop
With up to 3A of output, the USB-C Charger Cord supports up to 60W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone.
  • Efficient power delivery
    Equipped with USB Power Delivery (60 W), this 2m USB-C charging cable supports up to 60 W of power delivery, ensuring fast and efficient charging for laptops and other devices.
  • Durable design
    The cable's Thermoplastic elastomer (TPE) jacket and strain relief feature provide enhanced durability, making it resistant to everyday wear and tear.
  • High-quality connectivity
    Featuring shielded aluminum mylar foil with braid and nickel-plated connectors, this cable ensures reliable data transfer and charging capabilities, minimizing electromagnetic interference.
StarTech.com 2m (6ft) USB C Charging Cable, USB-C Cable, USB 2.0 Type-C Laptop Charger Cord, 60W 3A Power Delivery, TPE Jacket, USB-C Data Transfer Cable, M/M - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
USB Power Delivery (60W), sync and charge, strain relief, halogen free
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
5 / 9 / 12 / 15 / 20 V
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
American Wire Gauge (AWG)
24/30
Rated Voltage
Rated Current
3 A
Plated Connector
Nickel
Length
2 m
Outside Diameter
3.8 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE, EMI
Shipping Width
22.5 cm
Shipping Depth
12.5 cm
Shipping Height
1 cm
HM0Z StarTech.com USB-C Charging Cable, 240W PD - 1m In Stock £9.19
HM0Z StarTech.com USB-C Charging Cable, 240W PD - 2m In Stock £10.37
HM0Z StarTech.com USB-C Charging Cable, 240W PD Black 3m In Stock £13.36
HM0Z StarTech.com USB-C Charging Cable, 240W PD Black 4m In Stock £14.57
Length: 2m
