StarTech.com 2m USB-A to USB-C Cable
Quicklinx: J1MQWS00 Mfr#: USB2AC2MNC
Length: 2m
More than 50 In Stock
£7.24 ex VAT
£8.68 inc VAT
The 2 m (6.6 ft) USB-A to USB-C Charging Cable by StarTech.com combines powerful performance with durability, making it an essential accessory for charging and syncing devices. With a 480 Mbps data rate, this cable allows for fast data transfers, and it supports USB Fast Charge at 15 W. The aluminum mylar foil shielding and braided design offer excellent EMI protection while ensuring longevity with a lifespan of 10,000 insertions. Constructed with a thermoplastic elastomer (TPE) jacket, this cable is halogen-free, contributing to a more environmentally-friendly choice. The strain relief feature enhances flexibility and robustness, preventing damage at connection points. Both connectors are designed to withstand regular use, ensuring reliability for everyday tasks such as charging smartphones, tablets, and other devices compatible with USB-C technology.
  • Durable construction
    The cable is built with a thermoplastic elastomer (TPE) jacket, which provides flexibility and resilience against wear and tear.
  • Excellent EMI protection
    The aluminum mylar foil shielding combined with braid effectively reduces electromagnetic interference, ensuring stable performance.
  • High-performance data transfer
    With a data rate of 480 Mbps, this cable facilitates quick data synchronization, making it ideal for frequent use.
  • Versatile compatibility
    This USB-A to USB-C cable is compatible with a wide range of devices, providing a reliable solution for charging and syncing.
  • Efficient charging capabilities
    Rated for a current of 3 A, the cable supports faster charging for devices, enhancing user experience.
StarTech.com 2m (6.6ft) USB-A to USB-C Charging Cable, Charger Cord, M/M - USB-C cable - USB to 24 pin USB-C - 2 m
USB-C cable
Charge and sync, halogen-free, passive cable, USB Fast Charge (15W), 480 Mbps data rate, strain relief, 10000 insertions lifespanins, EMI protection
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
Rated Current
3 A
USB / USB 2.0
USB-C cable
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
22/30
Rated Current
3 A
Plated Connector
Nickel
Length
2 m
Outside Diameter
3.5 mm
45 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.4 cm
Shipping Weight
50 g
Length: 2m
