StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable
Quicklinx: DZ75BTBS Mfr#: USB2C5C2MW
Length: 2m
More than 50 In Stock
£13.23 ex VAT
£15.87 inc VAT
Power your USB Type-C devices. With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 2.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
  • Robust design
    Constructed with double shielding technology using aluminum mylar foil and braid, this cable ensures stability and resilience in various environments.
  • High power delivery
    Capable of delivering up to 100 watts of power, this cable meets the demands of modern devices, providing fast charging solutions.
  • Environmentally compliant
    This product adheres to RoHS and WEEE directives, ensuring that it is both safe to use and produced with environmental responsibility.
  • Flexible connectivity
    The 6 ft / 2 m length provides ample distance for connecting devices without restriction, making it ideal for both home and office setups.
  • Premium connectors
    Equipped with nickel-plated connectors, this USB-C cable ensures a reliable connection while preventing corrosion and wear.
StarTech.com USB C to USB C Cable - 6 ft / 2m - 5A PD - M/M - White - USB 2.0 - USB-IF Certified - USB Type C Cable - USB C Charging Cable (USB2C5C2MW) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Double shielded
Up to 100 Watts of power delivery
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Current
5 A
Thunderbolt 3 / USB 2.0
White
USB-C cable
Double shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
24/26
Rated Current
5 A
Plated Connector
Nickel
Length
2 m
White
90 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS, USB-IF, WEEE
DZ75 StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.41
DZ75 StarTech.com 3m 10ft USB C Cable w/ 5A PD In Stock £18.86
DZ75 StarTech.com 1m 3ft USB C Cable w/ 5A PD In Stock £10.17
DZ75 StarTech.com USB 2.0 - C to C w/ 5A PD - 6 ft / 2m In Stock £14.63
DZ75 StarTech.com 2m USB 2.0 Certified Power Delivery(5A) C to C White Cable In Stock £13.23
DZ75 StarTech.com 4m USB 2.0 Power Delivery(5A) C to C White Cable - M/M In Stock £13.94
DZ75 StarTech.com 50cm USB 2.0 Power Delivery(5A) C to C Cable - M/M In Stock £9.67
Length: 2m
