StarTech.com 2m USB 2.0 C to Mini B Cable
Quicklinx: D69PWS00 Mfr#: USB2CMB2M
Length: 2m
More than 50 In Stock
£7.71 ex VAT
£9.25 inc VAT
Connect USB 2.0 Mini-B devices to your USB Type-C or Thunderbolt 3 computer. This USB-C to Mini-USB cable lets you connect your USB 2.0 peripheral devices to USB-C computers or car chargers. For example, you can connect your camera to a USB Type-C laptop or desktop computer and download your latest photos or videos. You could also connect your Mini-USB GPS to a USB-C car charger.
  • Durable construction
    This cable features a PVC jacket and nickel-plated connectors which ensure a long-lasting usage experience. The robust design withstands daily wear.
  • High-quality shielding
    Incorporating aluminum mylar foil with braid, this cable provides effective shielding against interference to ensure optimal data transmission.
  • Versatile compatibility
    The cable is designed to connect USB-C devices to Mini-USB peripherals, allowing users to connect various devices and accessories.
  • Efficient data transfer
    Compliant with USB 2.0 standards, this cable enables reliable data transfer speeds, making it suitable for a range of applications from charging to syncing.
StarTech.com USB C to Mini USB Cable - 6 ft / 2m - M/M - USB 2.0 - Mini USB Cord - USB C to Mini B Cable - USB Type C to Mini USB (USB2CMB2M) - USB-C cable - 24 pin USB-C to mini-USB Type B - 2 m
USB-C cable
Shielded
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
Mini-USB Type B - male
Thunderbolt 3 / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
2 m
57 g
Connector
24 pin USB-C - male
Thunderbolt 3 / USB 2.0, RoHS, WEEE
Length: 2m
